3-Newcomer
Plotted values do not match vector-printed values
I am using Mathcad Release 15.0 and DatecodeN/A
Automatic scaled values on plot are different from the computed ones (when listed as a vector).
Here are the errors that I faced
None
    terryhendicott
    It plots in system units unless you specify as above.
    23-Emerald V
    "Here are the errors that I faced
    None "
    With no errors, there's nothing to complain about, is there?
    If there is a problem, please show it clearly. Attach the worksheet and indicate the problem.
    motan3-NewcomerAuthor
    3-Newcomer
    Hi.
    Thank you for the prompt reply.
    My understanding when was asked about "error"  is to provide some message generated by Mathcad, which does not exist.
    In fact, what I am looking for is an explanation on why on the plot the values (magnitude: E7) do not match the vector-printed values (magnitude E4),
    please see enclosed.
    terryhendicott
