Plus sign as Subscript
How do you have the plus sign "+" be a subscript? Every time I try to subscript the plus sign, it just becomes an operator. But I want it to be part of the subscript.
DJNewman
In math regions: Use ^
In text regions: Press = while holding down the ctrl key
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
using ^ causes it to be a superscript. I essentially use want to use the + as a symbol and not an operator
DJNewman
Ooooh I misread subscript as superscript because you kept talking about + and my mind associates those with superscripts.
Okay, so you want the + sign as a character, not as the math operator used for adding things. For example, like in a variable name, Variablevar+hello.
In that case.. you can't do that unless you do something goofy like use an alternate plus sign that isn't the + on your keyboard, like the ➕emoji, because that's just how variable naming rules are.
23-Emerald V
Normally you can get (almost) character in a variable by first naming the variable as a string (so within double quotes) and you can use the ordinary + :
Then you delete one quote (the other quote disappears with it):
Then you can give it a value:
and you can use it in an expression:
However, this does not work with a (literal) subscript, because you cannot create a string with a subscript, and you cannot change existing parts of a variable name to subscript.
It can be done with an index though, using the string trick as above, defining the index first as a separate variable that you then copy and paste to an index placeholder:
But you have to realise that the index Index+addon is a separate value that Prime will want to have a numerical value.
18-Opal
Eg:
Type V
CTRL  underscore to invoke subscript.
USE ALT 197  (etc) for other subscripts
Community Moderator
Hi @PS_12920773,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
