Run setup to add it to the installation of Worksheet Converter
It states MathCAD worksheet converter is not installed. Run setup to add it to the installation. Can someone help point me how to do this? Thanks!
I was able to get it installed by re-installing and adding this tool.  Now when I run the tool I get an error that the conversion has failed.  It is a 2001i version of MathCAD
23-Emerald V
Potentially the Mathcad  worksheets uses elements that are not supported in Prime.
Can you post the .mcd file so others can try it?
