7-Bedrock
Share files between Prime 7 and Prime 8
I have my own versions of Prime 7 and Prime 8.  My company uses Prime 7.  Is there any way to take the Prime 8 files that I created and convert them to Prime 7?
LucMeekesAnswer
23-Emerald V
Open the file in Prime 8, Copy all regions into a single area. Close the area.
Start Prime 7 on the same PC. Copy the area in Prime 8 and paste it into the empty sheet of Prime 7.
Save the file from Prime to a different name.
Copy all regions out of the area. Remove the area and save the file from Prime 7 again.
Be aware that during any of the steps Prime 7 may crash. If that occurs you could copy one or a few regions at a time...
If your Prime 8 file already contains areas, you'll just have to create area(s) for any sets of regions in between them, since you cannot embed an area into a area.
LucMeekes23-Emerald VAnswer
23-Emerald V
gshockxcc7-BedrockAuthor
7-Bedrock
Luc,
Sorry for the delay in replying.   This seems to be the only viable workaround.
Thank you.
