Silent install and uninstall
How do I silently install and uninstall Mathcad prime 10?
VladimirNAnswer
Take a look:
18-Opal
This is what Gemini AI says: with lot of waffle - you may have to weed a lot of it out.
Silently Installing and Uninstalling Mathcad Prime 10
1. Introduction
Mathcad Prime 10 stands as a robust software solution tailored for engineers and scientists who require a platform for performing, documenting, and sharing complex mathematical calculations.1 In enterprise environments, the efficient management of software deployments, updates, and removals across numerous workstations is paramount. Silent installation and uninstallation methods offer a streamlined approach to these tasks, minimizing the need for manual intervention and ensuring a consistent software state across all systems. This report aims to provide a comprehensive guide for IT professionals seeking to implement silent installation and uninstallation procedures for Mathcad Prime 10. By automating these processes, organizations can reduce user disruption, maintain software standardization, and improve overall operational efficiency.
2. Understanding Silent Installation and Uninstallation Concepts
Silent installation refers to the process of installing software without requiring any user interaction during the setup. This is typically achieved through the use of command-line arguments or pre-configured configuration files that provide the installer with all the necessary information to complete the installation process.5 The advantages of silent installation are numerous, particularly in large-scale deployments. Automation reduces the time and effort required to install software on multiple machines, ensuring consistency in the installation process and minimizing the potential for user error. Furthermore, silent installations can be performed in the background without interrupting user workflows, enhancing productivity and reducing downtime.
Silent uninstallation, conversely, involves the removal of software from a system without any user prompts or interaction. This is often a necessary component of automated software lifecycle management, allowing for the efficient removal of outdated or unwanted software. Silent uninstallation can also be crucial in scenarios where manual uninstallation is impractical, such as in automated deployment scripts or when dealing with a large number of systems. Common methods for performing a silent uninstall include utilizing specific command-line switches with the original installer, executing a dedicated uninstall executable provided by the software vendor, or leveraging the Windows Installer (MSI) framework, which offers standardized command-line options for uninstalling applications installed through MSI packages.6 Understanding these fundamental concepts is crucial for effectively implementing silent operations for Mathcad Prime 10.
3. Silent Installation of Mathcad Prime 10
3.1 Analyzing Official Documentation
Initial exploration of the official PTC website through support articles suggests that a straightforward "Silent Installation option is not available when installing" Mathcad Prime.8 These descriptions also mention the inability to create a customized installation package (MSI).8 This information might lead to the initial conclusion that silent installation is not directly supported. However, it is important to consider that these statements could refer to specific methods of silent installation, such as a simple command-line switch or a direct MSI-based approach. Further investigation of the full content of these articles, which often requires a login to the PTC support portal, is necessary to gain a complete understanding of the available options. Despite these initial indications, other information suggests that silent installation is indeed possible through alternative methods.
3.2 Leveraging setup.exe and the mathcad.p.xml Configuration File
Despite the initial statements about the unavailability of a direct silent installation option, user forums and community posts, such as those on ITNinja and Reddit, point towards a method involving the setup.exe installer provided by PTC in conjunction with an XML configuration file named mathcad.p.xml.9 This approach is further supported by PTC documentation itself, which mentions using the command <dvd>:/setup.exe –xml “<path to the.xml file stored in a temporary location>” to perform a silent installation.5 Another PTC resource also confirms the workflow for silent installation involves executing setup.exe with an associated XML file.5 This indicates that while a simple command-line switch for silent installation might not exist, PTC does provide a mechanism for automating the installation process using a configuration file. The earlier statements about the lack of a silent installation option likely refer to the absence of more conventional methods and highlight the need to utilize the XML-based approach.
3.3 Creating and Modifying the mathcad.p.xml File
The process of achieving a silent installation of Mathcad Prime 10 using the XML method typically involves first performing a manual installation on a test machine.9 During this manual installation, the setup.exe program generates a mathcad.p.xml file, which stores the configuration settings chosen during the interactive setup.11 This file is usually located in the directory C:\Program Files\PTC\Mathcad\Mathcad Prime <version>\bin\pim\xml\.9 Once this template XML file is obtained, it can be modified to suit the specific requirements of a silent deployment. Common modifications include embedding license server information within the file to automate the licensing process during installation.9 PTC even provides specific guidance on how to edit this XML file to activate Mathcad Prime during a silent installation.12 An example from a community post demonstrates the successful use of an edited mathcad.p.xml for deploying Mathcad Prime 7 via SCCM, suggesting the applicability of this method across different versions of Mathcad Prime.11 The mathcad.p.xml file plays a crucial role as an answer file for the setup.exe installer, enabling administrators to pre-configure various installation settings, including the crucial aspect of software licensing. While the internal structure of Mathcad Prime files involves a zipped archive with multiple XML files for worksheet data 13, the mathcad.p.xml file specifically governs the installation configuration.
3.4 Command-Line Syntax for Silent Installation
To initiate a silent installation of Mathcad Prime 10 using the mathcad.p.xml file, the standard command-line syntax involves running the setup.exe executable with the -xml parameter, followed by the full path to the customized mathcad.p.xml file.5 Examples of this syntax found in user forums include setup.exe -xml c:\yourpath\mathcad.p.xml and "%~dp0setup.exe" -xml "%~dp0mathcad.p.xml", which is particularly useful in batch scripts where the path to the setup.exe and XML file might be relative.9 PTC documentation also confirms the basic syntax as <dvd>:/setup.exe –xml “<path to the.xml file stored in a temporary location>”.5 Discussions on platforms like Reddit clarify that only one -xml parameter pointing to the configuration file is necessary.10 When this command is executed, the setup.exe installer reads the configuration details from the specified XML file and performs the installation in a non-interactive mode, effectively achieving a silent installation based on the pre-defined settings.
3.5 Handling Potential Issues and Interpreting Error Codes
Information regarding specific error codes encountered during a silent installation of Mathcad Prime 10 using the XML method is not readily available in the provided research snippets. However, general best practices for silent installations emphasize the importance of creating detailed installation logs to diagnose any potential issues. It is likely that the setup.exe installer for Mathcad Prime 10 supports options for generating log files, which would need to be investigated within the official PTC documentation. One user comment suggests that checking for launch conditions or custom actions that might be blocking the installation is a prudent step in troubleshooting failures.9 These conditions could be related to system prerequisites or conflicts with other installed software. Therefore, in the event of a failed silent installation, consulting the installation logs (if available) and reviewing system requirements would be the initial steps in identifying and resolving the underlying cause.
4. Silent Uninstallation of Mathcad Prime 10
4.1 Exploring Methods for Silent Uninstallation
Research indicates that multiple methods might be available for silently uninstalling Mathcad Prime 10. Resources from Revo Uninstaller mention several approaches, including using a third-party uninstaller, the standard Windows "Apps and Features" or "Programs and Features" control panel, the program's built-in uninstall.exe (if present), and utilizing an uninstall string with msiexec.exe.14 Documentation for another PTC product, Creo View, details the process of manual and silent uninstallation using msiexec.exe with the product code, suggesting a similar method could be applicable to Mathcad Prime.6 Furthermore, PTC itself acknowledges the existence of a "Silent uninstall procedure" for Mathcad Prime, although the specific steps are often behind a login requirement on their support website.15 An article mentions a silent uninstall procedure for Mathcad Prime versions 1.0 through 7.0, implying that a comparable procedure should exist for the more recent version 10.15 Given these various possibilities, the most likely candidates for a fully automated silent uninstallation of Mathcad Prime 10 are using msiexec.exe in conjunction with the product code or executing a dedicated uninstall.exe if one is included with the software.
4.2 Finding the Product Code for Mathcad Prime 10
Locating the product code for Mathcad Prime 10 is essential if the silent uninstallation is to be performed using msiexec.exe. Documentation related to Creo View 6 explains methods to retrieve product codes using tools like msiinv.exe or by examining the Windows registry. More general command-line tools like wmic product get name, IdentifyingNumber 17 or PowerShell commands such as Get-WmiObject -Class Win32_Product 18 can also be used to list installed applications and their corresponding product codes. PTC provides articles on how to locate the product code for single-user and student editions of Mathcad/Mathcad Prime, but accessing the detailed instructions typically requires logging into their support portal.19 Information from the PTC Community suggests that the product code might also be found in the PTC order confirmation email or through the user's account on the PTC support website.20 Therefore, obtaining the product code for Mathcad Prime 10 can involve using system tools to query installed applications or checking PTC-provided resources such as email confirmations or their support website.
4.3 Command-Line Syntax for Silent Uninstallation using msiexec.exe
The command-line syntax for silently uninstalling an application using msiexec.exe typically involves the /x switch followed by the product code enclosed in curly braces: msiexec.exe /x {<ProductCode>}.6 To perform a completely silent uninstallation without any user interface, the /qn switch can be added to the command.7 Additionally, to prevent an automatic system reboot after the uninstallation, the REBOOT=ReallySuppress argument can be included.7 Thus, a common command for a silent uninstallation of Mathcad Prime 10 using its product code would be msiexec.exe /x {ProductCode} /qn REBOOT=ReallySuppress. While it is also possible to uninstall using the original MSI file with the command msiexec.exe /x "c:\filename.msi" 7, using the product code is generally more reliable, especially if the original MSI file is not readily accessible. Research also indicates that an uninstall string, which often uses msiexec.exe with a specific product GUID, can be found in the system registry.14 While a specific GUID for Mathcad Prime 10 is not provided in the snippets, this illustrates another potential avenue for silent uninstallation using msiexec.exe.
4.4 Investigating a Dedicated uninstall.exe
Another potential method for silently uninstalling Mathcad Prime 10 is through a dedicated uninstall.exe file located within the software's installation directory.14 This directory is typically found under C:\Program Files\PTC\Mathcad Prime 10\ or C:\Program Files (x86)\PTC\Mathcad Prime 10\. An example from Creo 4.0 shows the use of an uninstall.exe for uninstallation 16, suggesting that Mathcad Prime 10 might also include such an executable. When using a dedicated uninstall program for a silent uninstall, command-line arguments such as -silent or -quiet are often employed to suppress any user interface. To determine the specific silent uninstall switches supported by the uninstall.exe for Mathcad Prime 10, it would be necessary to either consult the official PTC documentation or to try running the uninstall.exe from the command line with the /h or /help switch to display available options.
4.5 Strategies for Handling Potential Issues and Error Codes
Similar to silent installation, logging is crucial for troubleshooting any issues encountered during a silent uninstallation. When using msiexec.exe, verbose logging can be enabled by adding the /L*V <log file path> switch to the command.7 This will create a detailed log file that can be examined for error messages or other indicators of failure. Research suggests potential problems during uninstallation, such as the built-in uninstaller failing to start or missing files required for the process.14 These scenarios might necessitate manual intervention or specific troubleshooting steps beyond a simple silent uninstall command. It has also been noted that using the wmic product where name="PTC Mathcad Prime 5.0.0.0" call uninstall command might not be a reliable method for silent uninstallation, particularly for MSI-based applications.21 Therefore, utilizing msiexec.exe with the correct product code is generally considered a more dependable approach for silent uninstallation in such cases.
5. Working with the mathcad.p.xml Configuration File
5.1 Structure and Key Elements
The mathcad.p.xml file serves as a configuration blueprint for the Mathcad Prime installer. Examination of example snippets reveals that it contains key sections such as <INSTALL>, <UNINSTALL>, and <MSIFEATURE>.9 The <INSTALL> section typically holds the msiexec.exe command used for installing the software, often including parameters for silent operation (/qn) and preventing reboots (/norestart).9 It can also specify the installation directory using the INSTALLDIR property.9 The <UNINSTALL> section contains the command for uninstalling the application, which usually involves msiexec.exe with the PRODUCTCODE.9 A more detailed view of the <MSI> section within the mathcad.p.xml shows various attributes like PRODUCTCODE, UPGRADECODE, the filename of the MSI package (from), a unique identifier (id), flags for update and installation status (ignoreforupdate, install, installed), the name of the MSI (name), the platform (platform), the size of the package (size), and the software version (version).9 Crucially, the mathcad.p.xml allows for specifying installation properties through the <MSIARGUMENT> tag within the <MSI> section. This is where parameters like LICENSEPATHFORM and LICENSEPATH are defined to handle software licensing during the silent installation process.9 The presence of a <PROPERTY name="USE_TRANSFORM"/> tag also indicates the file's capability to incorporate transform files (MST) for further customization of the MSI installation.22
5.2 Advanced Configuration Options
Beyond the basic installation and licensing configurations, the mathcad.p.xml file offers several advanced options for tailoring the deployment process. One such option is the ability to modify the `` property within the XML file, which could be useful in network deployment scenarios where the installation files are located on a shared network resource.9 The capability to integrate MST (Microsoft Transform) files 22 provides a powerful mechanism for further customizing the MSI installation package. MST files allow administrators to define specific changes to the application's features, configuration, or even the user interface. Additionally, a query was raised regarding the possibility of preventing the creation of the "PTC Mathcad License Wizard" shortcut through modifications to the mathcad.p.xml file.22 While the answer to this specific question was not found in the research, it suggests that the XML file might offer granular control over various aspects of the installation, including the creation of shortcuts. These advanced configuration options make the mathcad.p.xml file a versatile tool for customizing Mathcad Prime 10 deployments to meet specific organizational needs.
5.3 Example Scenarios of Modifying mathcad.p.xml
To illustrate the practical application of modifying the mathcad.p.xml file, consider a few common scenarios:
Scenario 1 (Licensing): To automate the licensing of Mathcad Prime 10 during a silent installation using a license server, the following lines can be added within the <MSIARGUMENT> tags in the mathcad.p.xml file 9:
XML
<MSIARGUMENT>LICENSEPATHFORM="ServerAndPort" LICENSEPATH="7788@your_license_server"</MSIARGUMENT>
Replace "your_license_server" with the actual hostname or IP address of your license server.
Scenario 2 (Custom Install Directory): To specify a custom installation directory other than the default, the INSTALLDIR property can be used within the <INSTALL> tag 9:
XML
<INSTALL>msiexec.exe /qn /norestart /I "" INSTALLDIR="C:\Custom\MathcadPrime"</INSTALL>
Modify the path C:\Custom\MathcadPrime to your desired installation location.
Scenario 3 (Feature Selection): While the research snippets do not provide explicit instructions on how to selectively install or uninstall features via the mathcad.p.xml, the presence of <MSIFEATURE> tags suggests that this level of control is possible.9 It would likely involve modifying the install attribute of specific <MSIFEATURE> elements to either "Y" (install) or "N" (do not install). Further investigation of the official Mathcad Prime 10 documentation would be necessary to determine the exact syntax and available feature names.
These examples demonstrate how the mathcad.p.xml file can be tailored to automate and customize the installation process for Mathcad Prime 10, addressing common requirements like licensing and installation paths.
6. Prerequisites and Dependencies for Silent Installation
The provided research snippets do not explicitly detail specific prerequisites and dependencies for a silent installation of Mathcad Prime 10. However, general software installation requirements typically apply. These include ensuring that the target operating system is compatible with Mathcad Prime 10 (which is likely a recent version of Microsoft Windows, as indicated by various snippets).1 Sufficient disk space must be available on the target machine to accommodate the software installation. Furthermore, the user account performing the installation will generally require administrator privileges to make the necessary system changes. While not explicitly mentioned in the snippets for Mathcad Prime 10, some software might have dependencies on specific versions of the.NET Framework or other system libraries. A snippet related to Mathcad 15 mentions the need for MSXML.msi 23, but it is unclear if this is also a requirement for Prime 10. To obtain a definitive list of prerequisites and dependencies for Mathcad Prime 10 silent installation, it is crucial to consult the official installation guide provided by PTC. This documentation will provide the most accurate and up-to-date information regarding any specific system requirements that need to be met before attempting a silent installation.
7. Error Handling and Troubleshooting in Silent Operations
7.1 Common Error Scenarios
Several error scenarios can potentially occur during silent installation and uninstallation of Mathcad Prime 10. During installation, failures might arise from incorrect syntax or missing information within the mathcad.p.xml configuration file. Invalid or improperly formatted license information embedded in the XML file can also lead to installation errors or an unlicensed application. Insufficient user permissions on the target system are a common cause of installation failures. Additionally, if any prerequisites or dependencies are not met, the installation process might fail silently or with an error code. For uninstallation, a primary cause of failure is attempting to uninstall with an incorrect product code when using msiexec.exe. If the Mathcad Prime 10 application or related processes are running while an uninstallation is attempted, it could lead to errors or an incomplete removal. Corrupted or missing files required for the uninstallation process can also result in failures. In some cases, suppressing automatic reboots after installation or uninstallation might lead to an incomplete process, requiring a manual restart to fully complete the operation.
7.2 Techniques for Logging
Effective error handling in silent operations relies heavily on the use of logging. For installations initiated using setup.exe with the mathcad.p.xml file, it is important to investigate if the command syntax supports any parameters for enabling logging. The official PTC documentation should provide details on any available logging options for the setup.exe installer. When performing silent uninstallation using msiexec.exe, comprehensive logging can be enabled by including the /L*V <log file path> switch in the command. This will generate a verbose log file at the specified path, detailing each step of the uninstallation process and any errors encountered. It is also worth checking if the mathcad.p.xml file itself has any built-in options for logging the installation process. Examining these log files is often the first step in diagnosing the root cause of any silent installation or uninstallation failures.
7.3 Strategies for Addressing Prompts
Silent installations and uninstallations are designed to proceed without any user interaction or prompts. If prompts do appear during either process, it typically indicates an issue with the silent configuration or a fundamental limitation of the method being used. For silent installations using the mathcad.p.xml file, it is crucial to carefully review the XML file for any settings that might trigger an interactive prompt. Ensuring that all necessary configuration parameters, such as license information, are correctly specified can help prevent prompts related to licensing. When performing a silent uninstallation, particularly if using a dedicated uninstall.exe, it is important to use the correct command-line switches (e.g., -silent, -quiet) to suppress any user interface elements. If prompts related to files in use appear during uninstallation, a strategy is to ensure that all Mathcad Prime 10 applications and related background processes are closed before initiating the silent uninstall command. Using task management tools to identify and terminate any running Mathcad Prime processes might be necessary to avoid these prompts.
8. Community Insights and Best Practices
Insights and best practices shared by the user community on platforms like ITNinja and Reddit offer valuable supplementary information for performing silent installations and uninstallations of Mathcad Prime 10.9 A recurring recommendation is to first install Mathcad Prime on a test machine using the standard setup.exe and then capture the generated mathcad.p.xml file.9 This provides a baseline configuration file that can then be customized for silent deployments. The community discussions frequently highlight the need to modify the mathcad.p.xml file to include licensing details, such as license server information, to ensure automatic activation during silent installation.9 Many users find it beneficial to encapsulate the silent installation command (using setup.exe with the -xml parameter) within batch files or scripting tools to further automate the deployment process.9 For silent uninstallation, the community often advises using msiexec.exe with the product code of Mathcad Prime 10, along with the /qn and REBOOT=ReallySuppress switches for a fully silent and non-rebooting uninstall.6 These community-driven tips and solutions can provide practical guidance that complements the official documentation and helps in navigating potential challenges during silent operations.
9. Conclusion
Silently installing Mathcad Prime 10 can be effectively achieved by utilizing the setup.exe installer in conjunction with a customized mathcad.p.xml configuration file. This method, while not a traditional command-line silent install, allows for a high degree of automation and pre-configuration, including software licensing. The process involves obtaining a template mathcad.p.xml by performing a manual installation on a test machine and then modifying this file to include the desired settings. The silent installation is then initiated using the command setup.exe -xml <path_to_mathcad.p.xml>.
For silent uninstallation, the most reliable approach appears to be using the Windows Installer command-line utility, msiexec.exe, along with the product code of Mathcad Prime 10. The command msiexec.exe /x {ProductCode} /qn REBOOT=ReallySuppress will perform a silent uninstallation without requiring user interaction or prompting a reboot. Another potential method involves checking for and executing a dedicated uninstall.exe located in the Mathcad Prime 10 installation directory, using appropriate silent uninstall switches if available.
Before deploying these silent installation and uninstallation methods in a production environment, thorough testing in a non-production setting is strongly recommended to ensure the process works as expected and to identify any potential issues. While this report provides a comprehensive overview based on the available research, consulting the official PTC Mathcad Prime 10 documentation will offer the most up-to-date and specific information, including details on error codes and advanced configuration options. Additionally, the insights and best practices shared by the Mathcad user community can be a valuable resource for troubleshooting and addressing unique deployment scenarios.
Key Valuable Tables:
Table 1: Common mathcad.p.xml Configuration Parameters for Silent Installation
Parameter/Tag Name
Description
Example Value
Snippet ID(s)
INSTALLDIR
Specifies the installation directory for Mathcad Prime.
C:\Program Files\PTC\MathcadPrime10
9
LICENSEPATHFORM
Specifies the format of the license path (e.g., ServerAndPort, File).
ServerAndPort
9
LICENSEPATH
Specifies the path to the license server or the license file.
7788@your_license_server or C:\path\to\license.txt
9
<INSTALL>
Contains the msiexec.exe command and its arguments for installation.
<INSTALL>msiexec.exe /qn /norestart /I "" INSTALLDIR="[LP]"</INSTALL>
9
<UNINSTALL>
Contains the msiexec.exe command for uninstallation.
<UNINSTALL>msiexec.exe /x ""</UNINSTALL>
9
Table 2: Command-Line Arguments for Silent Uninstallation
Method
Command-Line Argument/Switch
Description
Snippet ID(s)
msiexec.exe with Product Code
/x {ProductCode}
Initiates the uninstallation process for the application with the given code.
6
msiexec.exe
/qn
Runs the uninstallation completely silently without any user interface.
7
msiexec.exe
Suppresses any automatic reboot after the uninstallation.
7
uninstall.exe (potential)
-silent or -quiet
Command-line switches often used by uninstall executables for silent operation.
16
Works cited
  1. Mathcad - Wikipedia, accessed on April 1, 2025, https://en.wikipedia.org/wiki/Mathcad
  2. What's New in PTC Mathcad Prime 10, accessed on April 1, 2025, https://www.mathcad.com/en/blogs/whats-new-in-ptc-mathcad-prime-10
  3. PTC Mathcad Prime 10, accessed on April 1, 2025, https://www.mathcad.com/en/whats-new
  4. User's Guide - Infrastructure Systems Research, accessed on April 1, 2025, https://www.kbofosu.com/mathcad/mathcad13_userguide.pdf
  5. Installation and Administration Guide, accessed on April 1, 2025, https://ptc-p-001.sitecorecontenthub.cloud/api/public/content/6ad58621a3bb45a0bf7bc45feebb55f9?v=8eb127b2
  6. Creo View - Performing a Silent Uninstallation, accessed on April 1, 2025, https://support.ptc.com/help/creo/view/r10.1/en/creo_view/install_config_guide/Deploying_6.html
  7. Uninstalling an MSI file from the command line without using msiexec - Stack Overflow, accessed on April 1, 2025, https://stackoverflow.com/questions/450027/uninstalling-an-msi-file-from-the-command-line-without-using-msiexec
  8. CS108521 - How to perform Silent Installation of Mathcad Prime - PTC, accessed on April 1, 2025, https://www.ptc.com/en/support/article/CS108521
  9. Software Deployment : Issue with MathCad Prime 2.0? - ITNinja, accessed on April 1, 2025, http://www.itninja.com/question/issue-with-mathcad-prime-2-0
  10. using XML in -Parameters : r/PSADT - Reddit, accessed on April 1, 2025, https://www.reddit.com/r/PSADT/comments/1czpal7/using_xml_in_parameters/
  11. Silent Install Mathcad Prime 6 using Microsoft SCCM - PTC Community, accessed on April 1, 2025, https://community.ptc.com/t5/Mathcad/Silent-Install-Mathcad-Prime-6-using-Microsoft-SCCM/td-p/676269
  12. CS351060 - How to edit XML file to activate Mathcad Prime during ..., accessed on April 1, 2025, https://www.ptc.com/en/support/article/CS351060
  13. Mathcad Prime 9.0 Scripting with XML Data - PTC Community, accessed on April 1, 2025, https://community.ptc.com/t5/Mathcad/Mathcad-Prime-9-0-Scripting-with-XML-Data/td-p/903161
  14. How to completely uninstall PTC Mathcad Prime, accessed on April 1, 2025, https://www.revouninstaller.com/preview-log/?pid=10371&pname=PTC%20Mathcad%20Prime
  15. How to uninstall Mathcad Prime silently - PTC, accessed on April 1, 2025, https://www.ptc.com/en/support/article/CS198163
  16. Solved: Creo 4 Uninstall Piece by Piece - PTC Community, accessed on April 1, 2025, https://community.ptc.com/t5/System-Administration/Creo-4-Uninstall-Piece-by-Piece/td-p/427733
  17. Using msiexec to uninstall programs - Super User, accessed on April 1, 2025, https://superuser.com/questions/841387/using-msiexec-to-uninstall-programs
  18. Mass uninstall by msiexec : r/sysadmin - Reddit, accessed on April 1, 2025, https://www.reddit.com/r/sysadmin/comments/qbg7w3/mass_uninstall_by_msiexec/
  19. How to locate product code for single user and student edition of Mathcad - PTC, accessed on April 1, 2025, https://www.ptc.com/en/support/article/CS30357
  20. Solved: Product Code - PTC Community, accessed on April 1, 2025, https://community.ptc.com/t5/Mathcad/Product-Code/td-p/823881
  21. Unable to use silent command to uninstall in Mathcad Prime - PTC, accessed on April 1, 2025, https://www.ptc.com/en/support/article/CS294414
  22. Property "USE_TRANSFORM" in mathcad.p.xml ... - PTC Community, accessed on April 1, 2025, https://community.ptc.com/t5/Mathcad-Installation/Property-quot-USE-TRANSFORM-quot-in-mathcad-p-xml-How-to-pass/td-p/905612
  23. SCCM Package – MathCAD 15 - Puskar on Tech - WordPress.com, accessed on April 1, 2025, https://windowsmasher.wordpress.com/2012/03/11/sccm-package-mathcad-15/
VladimirN24-Ruby IVAnswer
Take a look:
Community Moderator
Hi @KM_12972132,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
