Sep 2, 2025 10:41 AM UTC
The license file downloaded today does not contain the license code intended to run Mathcad 15.0.
In January 2024 the license file contained following INCREMENT blocks:
INCREMENT MathcadPrime
INCREMENT MATHCAD
INCREMENT 254
INCREMENT 255
INCREMENT 256
INCREMENT 257
Today the license file contains following INCREMENT block, only:
License file belongs to old permanent locked Mathcad license bought in the distant past.
Can someone explain it? Maybe @DJNewman?
Sep 11, 2025 7:49 AM UTC
@vnamboodheri wrote:
@MartinHanak
Thanks for your reply!
I have created a case with our License management department C17912794.
You should hear from the team in some time.
Best Regards,
Vivek N
Community Moderator
Hi Vivek,
today I closed C17912794, because the very same problem was resolved via customer's case C17908925. The problem was caused by missing information in PTC's license database. After correcting this information, license generator is generating proper license file.
Sep 8, 2025 6:31 AM UTC
I would like to get an answer from a responsible person at PTC. Can you arrange it?
@vnamboodheri
@Catalina
Thanks in advance for your help.
Catalina
Community Manager
Sep 8, 2025 6:38 AM UTC
Hi @MartinHanak,
Thanks for the heads-up. We'll address this and see what can be done.
Best regards,
Catalina | PTC Community Manager
