Apr 29, 2013 5:41 PM UTC
WriteSTL Custom Function
Full list of worksheets
WriteSTL allows Mathcad users to create 3D models mathematically using PTC Mathcad then save them as STL files, perfectly suited for incorporation to CAD assemblies.
Along with the README, the WriteSTL.zip file contains two worksheets, showing 2 different matrix styles possible to generate 3D models. WriteSTL takes an array of triangle vertices. The included PTC Mathcad worksheets demonstrate inline routines to convert each matrix type to triangle vertices arrays.
Also included is the WriteSTL Custom Function compiled and linked for the Windows 7 64-bit platform. The MS Visual Studio project with source is included for anyone needing to build for different Windows Platforms. Microsoft has a free, Express version of Microsoft Visual Studio customers are using to successfully build PTC Mathcad Custom Functions.
May 19, 2013 12:02 PM UTC
Can we please see the file in older version for Mathcad 14.
Cheers.
May 20, 2013 9:10 PM UTC
Just attached
Nov 2, 2013 8:38 PM UTC
Below are screenshots of the contents of this file:
Nov 15, 2013 7:19 AM UTC
Generate STL (STereoLithography) file in Mathcad 14/15: http://communities.ptc.com/docs/DOC-4620
Nov 16, 2013 12:28 AM UTC
Thank you Vladimir for sharing this work.
Nov 16, 2013 3:01 PM UTC
You're welcome.
Jan 3, 2014 11:05 PM UTC
Hi Anna Giangregorio, Brent Edmonds, MathCad
Thank you for this upload.  Especially the source code so it can be now also be made for windows 7, 32 bit.
Very usefull and much appreciated.  STL is standard format read (or can be converted to CFD meshes) by many CFD open source fluid flow solvers.
Regards
Terry
Jan 4, 2014 12:21 AM UTC
Function can be improved by adding the normals to the triangles making up the STL surface.  It only uses 0,0,0.
Surface normals are used by software that uses STL files to determine which is the front and back orientation.  They can also be used with a trick to help calculate the area of a triangulated STL surface.
Here is adjusted cpp file.  Input is a matrix with now four instead of three rows per triangle.  First row is normal of face, followed by original three rows of coordinates of corners.
MathCad can calculate these normals and adjust the matrix before submission to the writeSTL function.
Jan 4, 2014 12:32 AM UTC
Terry Hendicott 03/01/2014 4:21 PM
// WriteSTL.cpp : Defines the exported functions for the DLL application.
#include "StdAfx.h"roes
#include "mcadincl.h"
#include <stdio.h>
    LRESULT WriteSTLFunction( LPCOMPLEXSCALAR result,
        LPMCSTRING      filename,
                                LPCOMPLEXARRAY     mat );
    FUNCTIONINFO    WriteSTL =
    "WriteSTL",                                    // Name by which mathcad will recognize the function
    "filename,mat",                                            // transpose will be called as WriteSTL(filename,mat)
    "returns a success"  ,                   // everything work?
    (LPCFUNCTION)WriteSTLFunction,                 // pointer to the executible code
    COMPLEX_SCALAR,                                  // the output is a result flag
    2,                                              // the function takes on 2 arguments
    { STRING, COMPLEX_ARRAY}    // the input type is a complex array
        FILE *fp;
  int i;
  fp = fopen(filename->str,"w");
  // Mathcad matrices are col x row via API, not row x col like the rest of the world
  fprintf(fp,"%s\n","solid Mathcad_Surface");
  for (i=0; i<mat->rows; i+=4) {
   fprintf(fp,"facet normal %f %f %f\n",mat->hReal[0][i],mat->hReal[1][i],mat->hReal[2][i]));
   fprintf(fp,"outer loop\n");
   fprintf(fp,"vertex %f %f %f\n",mat->hReal[0][i+1],mat->hReal[1][i+1],mat->hReal[2][i+1]);
   fprintf(fp,"vertex %f %f %f\n",mat->hReal[0][i+2],mat->hReal[1][i+2],mat->hReal[2][i+2]);
   fprintf(fp,"vertex %f %f %f\n",mat->hReal[0][i+3],mat->hReal[1][i+3],mat->hReal[2][i+3]);
   fprintf(fp,"endloop\n");
   fprintf(fp,"endfacet\n");
  fprintf(fp,"%s\n","endsolid Mathcad_Surface");
  fclose(fp);
        result->real = 1;
        return 0;               // return 0 to indicate there was no error
Can provide the MathCad14 file with the small program that adds the normals but no idea how to upload a MathCad file only images of limited size and videos can be added in this web page.
Regards
Feb 21, 2014 8:19 PM UTC
Hi Terry,
this is great. I do not see your attached CPP file. can you email me? Then I can get it posted.
And I can share with VladimirN and maybe he'll update his Mathcad 14 version.
John
