Accessing Kepserver tag from external code
There is requirement, that in a particular condition a Tag's value in the Kepserver has to be changed.
I can detect that particular condition externally (though nodejs service), now how do I access this Kepserver tag from my nodejs service.
Is there any API that Kepserver provides to connect to its device tags and alter.
Please suggest.
Sri1
Greetings,
KEPServer has the ability to enable our Config API to make changes to channel/device/tag properties, but not the tag values. You would need to use some sort of client application to make those changes, Kepware does not have a client that is provided apart from the OPC Quick client, which is just a test tool
Kind Regards,
Andrew Black
Senior Technical Support Engineer
Greetings,
Kind Regards,
Andrew Black
Support
Hi @Sri1.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
