Anyway to duplicate properties in Manufacturing Apps?
I am using manufacturing apps to create assets here. I have 10 lines and each line has a number of assets. For each asset I have a few additional properties to define.
I need to go to each asset I created and define these properties which is going to take some time. Is there any faster way to do it? I do not want to go to composer and define it because I don't fully understand the abstraction of the "add additional properties" function in the manufacturing apps UI (for example a value stream is automatically created in the backend etc??? just guessing here). If it is fully okay to go composer to use thing shapes I will do that, but prefer to hear the thoughts of developers here first.
PS: The current UI does not remember which kepware tag I last accessed so for each asset I have to traverse the hierarchy of my kepware tags repeatedly. Can this be set up as a feature request? Also if the tag field is made an editable string, one can quickly copy, paste and edit rather than traversing.
PaiChungAnswer
22-Sapphire I
The best way to do this, if your Properties are all homogeneous, to create a ThingShape and add that to the model, you do need the full version of Thingworx for that.
Besides that I actually created an Import from CSV for the Manufacturing app, that also would require the full version of Thingworx and the Parsley extension
PaiChung22-Sapphire IAnswer
22-Sapphire I
For additional information about this, please see the response from Varathan Ranganathan to a similar request in this thread:
Thing Templates and Shapes using Manufacturing Apps
