BMCoreUI conflict with MFA 8.5.2
I wanted to use the unofficial BMCoreUI extension and found that when I install it, I get an empty list of assets in the asset advisor. It seems to conflict with the official Collection Widget.
Does anybody have experience on using MFA along with the BMCoreUI extension? How did you solve the incompatibility problem?
Thank you.
Iker
IkerAnswer
The developer has released a new project that merges BMCoreUI and all of its dependent widgets into a single package whose contents are wrapped in an IIFE to avoid any conflict with the declarations in the Thingworx runtime, essentially causing Core UI and its widgets to live in their own private scope.
You can find it here: https://github.com/ptc-iot-sharing/BMCoreUIWidgets
Support
Hi @Iker.
Where did you obtain the BMCoreUI extension?  If you can provide more information, and your steps for recreating the issue, we can test it here.
--Sharon
Iker1-VisitorAuthor
Hi @slangley
The BMCoreUI is available at GitHub https://github.com/ptc-iot-sharing/BMCoreUI
On the latest versions of Thingworx there is a compatibility issue with the collection widget and I was wondering if any other user was able to find a fix / workaround to be able to use this extension.
Thank you.
Iker
Support
Hi @Iker.
I'm trying to track down someone who may be able to respond to your inquiry.
--Sharon
