Clear the KPI calculations after SKU change just like Shift change
Is there a way to clear the KPI calculations just like they do after a shift change? I am trying to find the same service you use for shift change so that I can run that same code when we do a SKU change. This way it will reset the APT and PBT time info. Please direct me which service clears those APT and PBT or how I can change them to zero.
thanks
Support
Hi @mpaisley90
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
