Communication failure between Industrial Connectivity and Foundation
I have the same problem and basically the same configuration as showed. I'm able to see the data on the OPC quick client, I have "logical Non-Blocking" under protocol mode.
There's a message displaying "Error pushing property updates to thing" not sure if it's something related to it,
Hope you can help me,
Thank you,
slangleyAnswer
Support
Hi @@chavarria.
Please take a look at this article from our knowledge base to see if this might explain the issue you're having.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @@chavarria.
--Sharon
Support
Hi @chavarria.
If the previous response helped to answer your question, please mark it as the Accepted Solution for the benefit of others on the community.  If you still need assistance, please provide additional information.
--Sharon
