Communication with OPC UA Server
I am Rynaldi. I have a B&R PLC running an OPC-UA Server and am trying to connect it somehow to Thingworx.
What is the possible way to do this actually? I've read several posts in the forums but they are mentioning different methods, such as using the OPC UA Client from the marketplace (which somehow I couldn't find anymore in the marketplace), using Kepware Server, using KepServerEx. So I'm confused what is the latest method to communicate with an OPC UA server running in a PLC actually?
I actually have access to the Thingworx Manufacturing Apps as well. Would that be any help for the OPC UA communication?
Later, I want to use this information in the Vuforia Studio actually. The idea is to get the real information from collected by the PLC and present this information in the AR Experience designed in Vuforia Studio.
I would appreciate any help 🙂
Best regards,
Rynaldi Maydrian Lauren
ganejaAnswer
Hello @rynaldi95
You can refer the below link for connect to OPC servers
https://support.ptc.com/help/thingworx_apps/r8.5/en/index.html#page/thingworx_apps/ThingWorxAppsSetupConfig/kepserverex_connections.html
Gunjan Aneja
ganeja5-Regular MemberAnswer
Hello @rynaldi95
Gunjan Aneja
Support
Hi @rynaldi95.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
