6-Contributor
CWC with an existing Thingworx instance 9.3.1
I have installed CWC on a MSQL DB. I installed Thingworx  9.3.1 on a separate DB with Navigate. Can this configuration work? Otherwise, does someone help me to find a solution?
SebBAnswer
The latest CWC (3.1.0) requires at least ThingWorx 9.3.5, so there is no guarantee it works on our setup.
Support
Hi @SC_10200351
What issue are you facing?  What version of CWC did you install?
We'll have to research this but it would be helpful to have as much info as possible.
--Sharon
SebB13-AquamarineAnswer
