Duplicate asset advisor mashups are not loading after an upgrade from 8.4.4 version to 8.5.2
The duplicate mashups that were available in the 8.4.4 version in my application are now not loading after a version upgrade but the Asset advisor is loading when we navigate from PTC.FactoryConsole.
sonali1Answer
Thanks Himanshu for the support.
The issue got resolved. It was happening due to deprecated services being used so by changing the points of the services its been fixed.
Thank You
Sonali Patro
Hi @sonali1 : The customization needs to be done again after the upgrade because a new launch point thing PTC.Factory.C_LaunchPointConfigurationThing_[ReleaseVersion] will be used by the application and custom mashups needs to be added in the launchpoint configuration again.
Refer help center link https://support.ptc.com/help/thingworx/apps/r9.0/en/index.html#page/thingworx_apps%2FCustomizing_the_Apps%2Fupgrade_and_customizations.html%23wwID0EELZO
for details.
Himanshu
sonali11-VisitorAuthorAnswer
Thank You
Sonali Patro
