How to convert date time when import csv file
When I upload csv file into system, date time format is not matched. below I attached file I want to upload. this coding I used to import csv file
//try
logger.info("FIle Name = "+FilePath);
var csvInfotable = Resources["CSVParserFunctions"].ReadCSVFile({
path: FilePath /* STRING */,
columnMappings: undefined /* STRING */,
hasHeader: true /* BOOLEAN */,
longitudeField: undefined /* NUMBER */,
dateFormat: undefined /* STRING */,
fileRepository: "SystemRepository" /* THINGNAME */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: undefined /* STRING */,
stringDelimiter: undefined /* STRING */,
dataShape: "GF_Datashape_EngineeringIm" /* DATASHAPENAME */
logger.info("successful");
var rowcsv;
var tableLengthCSV = csvInfotable.rows.length;
logger.info("tableLengthCSV = "+tableLengthCSV);
//add equal
for (var i=0; i < tableLengthCSV; i++)
logger.info("Processing the row :"+i);
rowcsv = csvInfotable.rows[i];
var date = rowcsv.timestamp;
var formattedDate = parseDate(date, "YYYY-mm-dd HH:MM:SS");
var query = {
filters: {
type: "And",
filters: [{
type: "EQ",
fieldName: "source",
value: rowcsv.source
type: "EQ",
fieldName: "tags",
value: rowcsv.tags
type: "EQ",
fieldName: "sourceType",
value: rowcsv.sourceType
type: "EQ",
fieldName: "location",
value: rowcsv.location
type: "EQ",
fieldName: "key",
value: rowcsv.key
type: "EQ",
fieldName: "timestamp",
value:formattedDate
type: "EQ",
fieldName: "ID",
value: rowcsv.ID
type: "EQ",
fieldName: "Category",
value: rowcsv.Category
logger.info("not successful");
// EXECUTE THE query
var Datatable = me.QueryDataTableEntries({
query: query /* QUERY */
//if( Datatable.length >0 )
logger.info("Datatable.rows.length "+Datatable.rows.length);
if( Datatable.rows.length >0 )
logger.info("Record is available already");
//Datatable.Date = rowcsv.Date;
Datatable.Year = rowcsv.Year;
Datatable.Month = rowcsv.Month;
Datatable.Budget = rowcsv.Budget;
Datatable.Category = rowcsv.Category;
Datatable.Value = rowcsv.Value;
me.UpdateDataTableEntries({
values: Datatable /* INFOTABLE */
else
logger.info("Working on the else part");
var params = {
infoTableName : "MyInfoTable",
dataShapeName : "GF_Datashape_EngineeringImport"
me.AddDataTableEntries({ values: me.CreateValuesWithData({ values: {
Year:rowcsv.Year,
Month:rowcsv.Month,
Budget:rowcsv.Budget,
Category:rowcsv.Category,
Value:rowcsv.Value
//After update and insert csv file
//catch(err)
// logger.error(err);
this is data shape I created and its name is GF_Datashape_EngineeringIm.
attached file also includes my error when I uploading csv file into system
how to fix this issue? thank you
vinakumarAnswer
Would you please try specifying the columnMappings field and see if it helps to resolve the issue.
columnMappings - STRING:
  • A semi-colon (;) separated string defining the mappings between the CSV columns and the Data Shape columns
    • Columns that map to a Data Shape field should contain the corresponding field name from the data shape
    • Columns that should be ignored should simply be skipped by inserting another semicolon (Field1;;Field2;Field3)
      • Location data (longitude/latitude)
        • If present will be populated using separate parameters
        • Only one of the two data columns needs to be included in the mapping
        • The other can be skipped
vinakumar12-AmethystAnswer
Support
Hi @xiaoqw.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
