How to custom the alert detail mash in mfg. app?
I want to add the 'message' column into the alert grid to show the current value and limit value. But I can not find a way to custom the alert detail mash. It's not included in the configuration of thing 'PTC.Factory.C_LaunchPointConfigurationThing_8.3.0_05'.
hchananaAnswer
Hi @zhuwenxi,
You need to create a custom alert monitoring mashup and need to replace with the pre-defined alert monitoring mashup.
You can replace the existing mashup in PTC.FactoryConsole.C_DataTable_[ReleaseVersion] for PTC.Factory.AlertMonitor
PFB screenshot for reference
Capture
You also need to set PTC.FactoryConsole.C_DataTable_[ReleaseVersion] in TilesDataTable of PTC.Factory.C_LaunchPointConfigurationThing_[ReleaseVersion]
Capture2
Himanshu
Greetings @zhuwenxi,
Please check the mashup PTC.SCA.SCO.ConfigurationAndSetup.C_AlertsConfigurationMashup_[ReleaseVersion] and launch point key is AlertsConfigurationMashup.
Himanshu
zhuwenxi12-AmethystAuthor
AlertsConfigurationMashup is only for alert configuration. What I need to custom is the alert monitoring mashup, that is not included in PTC.SCA.SCO.ConfigurationAndSetup.C_AlertsConfigurationMashup_[ReleaseVersion] launch point.
hchanana16-PearlAnswer
Hi @zhuwenxi,
Capture
Capture2
Himanshu
