How to disable purge data in MFG app?
Hello everyone
I need to collect the data all time.
I found purge data service in Thingworx MFG app customize guide.
How i disable purge data service in "PTC.Factory.MidnightPurgeWeekOldHistoryScheduler" thing?
First time, I try to disable it by change the enable properties inside the thing. But, It not working.
Enable properties is change to "True" after I refresh browser.
Hi @ssriuaipornchai ,
Can you please try executing DisableScheduler service of PTC.Factory.MidnightPurgeWeekOldHistoryScheduler.
This will set the Enabled property value to false.
Himanshu
Good job.
This solution is working.
Thank you.
Please mark as the correct response as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
