Implement worker guidance with ThingWorx and Operator Advisor? Looking for Courses/Tutorials
Hey,
atm we are planning to build a worker guidance PoC with ThingWorx and Operator Advisor.
I'm looking for a tutorial/course at PTC academy/Youtube etc. on how to install & use the Operator Advisor with ThingWorx properly.
1) Does anybody of you have a good recommendation?
2) Is it a good idea to implement a worker guidance with Operator Advisor and Thingworx? Any tips?
Thank you very much
Phid
Is
wcuiAnswer
Operator Advisor Help Center can be opened as below.
1. open https://www.ptc.com/en/support/help
2. select thingworx
3. select thingworx Operator Advisor 8.5
    https://support.ptc.com/help/thingworx_operator_advisor/r8.5/en/
Inside the HC, there are several examples for user to refer to.
https://support.ptc.com/help/thingworx_operator_advisor/r8.5/en/#page/operator_advisor%2FThingWorxOperatorAdvisor%2Fuser_interface_components.html%23
please check if above is what you need.
wcui16-PearlAnswer
2. select thingworx
Support
Hi @PD_9717258.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
