"IndustrialGateway" Thing Template Logged Properties Causing Issues.
The "IndustrialGateway" Thing Template has several of its properties logged, which is resulting in our "value_stream" database table getting loaded full of needless data (for our use).  Is there a way to turn this off, or is the solution to create a schedule job that purges this data?
This is mostly a problem on our dev environments that are using MS SQL Express.
Hi @bmehringer ,
Do you have any value stream assigned to Industrial Gateway thing?
If it is there you can remove the value stream.
Himanshu
Emeritus
Hi @bmehringer,
I just wanted to follow up to see if the response from @hchanana answered your question.  If so, please mark his reply as the Accepted Solution for the benefit of others in the Community.  If not, can you please share your current status?
Thanks!
Leigh
