Installing the extension ThingWorx-Apps-8-5-2-extension-bundle on ThingWorx 8.5.4-b222 fails
The installation of the extensions fails with several error messages. ThingWorx is installed with MS SQL Server. Dependencies have been installed already. Also Asset Remoting has been installed before.
It is not the extension import policy in platform_settings.json.
Does anyone have a hint?
Thank you.
pjahn16-PearlAuthor
Solved.
Double slashes written by the installer for the path to ThingWorx Storage in platform_settings.json are causing the problem. I am sure there will be a fix by PTC soon.
Support
Hi @pjahn.
Please provide specifics on the change you made in platform-settings.json.  I would like to test this and create a case for engineering if one does not already exist.
--Sharon
pjahn16-PearlAuthor
Sure.
Before (importing the extensions failed):
Fixed (importing the extensions works):
