Problem with Manufacturing Apps 8.4 trial import DemoFactoryDataSet.zip
I have installed Manufacturing Apps 8.4 trial and KepserverEx 6.6 but when I am doing Connect Factory Assets Using Control Advisor (Guide 1) in developer portal, I have problems in step 3 when I have to import DemoFactoryDataSet.zip. I attach the images of errors. Could you help me with that?
Thank you in advance
Best regards,
Luis
SebBAnswer
Hey @ljam
this is a known issue. The Demo Data Set does not work for the 8.4 version.
In the developer portal we still have 8.3 as version for the guys, so the data set is also for 8.3.
Here is a updated version of the Demo Data Set for 8.4
Let me know if you have any issue with the import.
Seb
SebB13-AquamarineAnswer
Hey @ljam
Seb
ljam1-VisitorAuthor
Hola @SebB,
Thank you so much Seb, I haven´t had problems with the import.
Thank you,
BR,
Luis
