Oct 20, 2026 8:18 PM UTC
SCPa Cards, Tooltips, and Headers section Information tab
I’m trying to get the information tab to show up in SCPa under the cards, tooltips and headers section under asset monitoring and can’t seem to get it to show up. What else do I need to modify to get it to show up?
No matter what I do I can’t seem to get it to show up in the mashup.
Thank you in advance
We’re using 9.7 and 10.1.1 (dev vs prod)
Wayne
Support
Oct 22, 2026 3:23 AM UTC
Hi ​@WT_10437065,
Are you talking about the cards in AMU (Asset Monitoring and Utilization)?
To better understand the issue, could you please share screenshots illustrating your expected outcome and the current behavior you are seeing? In addition, kindly advise which documentation you are referencing and list the configurations/steps you have done.
Thanks, Tony
Oct 22, 2026 4:22 PM UTC
If it would let me post an image that would be great. Can’t put in an image or an attachment. Gives an error.
I’ll describe it best I can.
It’s in SCPa first of all. Theres a left side list of administrative functions and under Asset monitoring, cards,tooltips and headers section there's an Information tab that allows you to put in properties to sho in an information tab on a given mashup tied to a specific template. I cannot get that information tab to show up.
Hope this helps but understand if it does not.
Thanks in advance
Wayne
Oct 26, 2026 8:49 PM UTC
Hello Wayne,
I lead the SCPA Task Force and am happy to help you diagnose this.
I understand that you are able to add properties to the Admin in the Information tab but the Information tab is not showing for users in the Asset Details view? If that is the case, there’s a few things that control that. On the menu itself, it runs the GetMenuVisibilityInformation service on the PTCTS.AssetMonitoring.Manager to see if it should be displayed or not. That service runs the GetPTCInformationModelForAsset service on the Thing. This service is provided by PTCTS.AssetMonitoring.ModelLogic_TS on your asset template. Does that service run correctly on your Thing that you’re expecting to see information?
