Shift Configuration in Mfg Apps
Hi All,
I am using Thingworx Mfg Apps 8.4.0. I see the Shift Start Time and Shift Duration as asset properties which are configured via  Planned Operation time Start and Duration in Configuration and setup tile. I wanted to understand how this works. Whether this implies that I can have only one shift in a day. If not how can i configure for multiple shifts. Also is there any mechanism to configure the break timings in a shift?
Please provide your inputs.
gevaAnswer
Check out this help centre page about setting up shifts and schedules for KPI calculations.
https://support.ptc.com/help/thingworx_apps/r8.5/en/#page/thingworx_apps%2FThingWorxAppsCust%2Fconfiguring_kpi_calculation.html
I do not believe that there is presently support for breaks.
geva15-MoonstoneAnswer
koushal1-VisitorAuthor
hi,
Thanks for your response.
Can we do shift configuration in 8.4 or is it available in 8.5 onwards?
One more question,
I see the status timeline for Asset in Asset Advisor Mashup. Can you please let me know where are we storing the data for Asset Status. I know that we are defining the machine status as an expression in Configure and Setup Mashup. Please let me know if any document available from which i can get to know more about how asset status data are stored and retrieved?
Hi @koushal ,
Shift configuration is available form 8.5 onwards.
I hope below link address your another question:
https://support.ptc.com/help/thingworx_apps/r8.5/en/index.html#page/thingworx_apps/ThingWorxAppsSetupConfig/specifying_status_expressions.html
Gunjan Aneja
Support
Hi @koushal.
I have marked the Accepted Solution for this post.  If you disagree with my choice, please let me know.
Thank you for your participation in our community.
--Sharon
