signed extension file does not match digests
I want to install Manufacturing apps from Operator advisor.
I have Thingworx 9.1.14
I downloaded the files in version: ThingWorx-Apps-9-1-1-extension-bundle (46 MB)
I get this error when importing extensions.
OA_OperatorAdvisor_7bb8d379-1865-4859-bae5-e24aee8c33d4\OA_OperatorAdvisor.zip signed extension file does not match digests
sco-OrgUserGroup_ce8aa723-601c-4121-9c5e-349c4831e1b0\sco-OrgUserGroup.zip signed extension file does not match digests
At the moment I notice them in two extensions.
I imported the extensions in the order from this article.
https://www.ptc.com/en/support/article/CS321570
How can I fix these import errors?
Do I really need to install another version of TWX?
Thank you for your answers.
Janek
hi JK_10565232
below article explains why this error occur.
please refre to the Cause/Resolution sections and find a proper way to fix.
https://www.ptc.com/en/support/article/cs273354
Thank you
hi JK_10565232
Below article says Manufacturing Apps 9.1.1 is compatible with ThingWorx 9.3.3 or newer versions so TW9.3.7 should be fine.
Article - CS376896 - ThingWorx Manufacturing Apps 9.1.1 compatibility with ThingWorx Platform 9.3.x (ptc.com)
You can download extensions of Manufacturing Apps 9.1.1 from below path:
PTC eSupport > Download Software > ProductFamily : ThingWorx Foundation > Release 9.1 > ThingWorx Manufacturing & Service Apps Extension
For how to import  Manufacturing Apps extensions , please follow the help center.
https://support.ptc.com/help/thingworx/apps/r9.1/en/#page/thingworx_apps/Installation_and_Setup/importing_the_thingworx_apps_extension.html#
