Status refresh in Asset Advisor
- 1 reply
- 1541 views
- Translate All
I defined the status table and one alert basing the same asset property, e.g. status.
It happens that the alert is immediately triggered as soon the status property value changes, while the status changes after some seconds (about 30 seconds).
Then for some seconds the Asset Advisor monitor shows the Asset still 'Running' (should be 'Planned Downtime') while the Alert is active.
Is this behavior correct? Many thanks Martina
