Thingworx Alert History - EndTime & Duration
I am using the MFG apps to create Alert templates for separate alert states (stopped, faulted, offline, manual). Everything works fine but I would like to get the timestamp for the End Time and total Duration of the alert. Similar to the Alert Summary. Per https://support.ptc.com/help/thingworx/apps/r9.1/en/#page/thingworx_apps/Exploring_the_Apps/alert_monitoring.html
Support
Hi @LP_10027711.
We see in the screenshot the time the alert happened and the duration.  You mention "total Duration".  Can you explain what you mean?
Are you expecting the End Time to be the time the Ack occurred?
--Sharon
I found a solution to my problem. thank you
