Oct 23, 2026 8:10 PM UTC
ThingWorx Applications 10.2 landing page is blank after successful CWC installation
Hi Team,
I have installed ThingWorx Platform 10.2 and Connected Work Cell (CWC) 10.2. The CWC installation completed successfully, and all required extensions were imported successfully.
However, when I open the ThingWorx Applications landing page, the header and All Applications (9-square) icon are displayed, but the landing page is completely blank. None of the expected application tiles/icons are displayed.
I have verified the following:
  • CWC installation completed successfully.
  • CWC extensions were imported successfully.
  • The COREUI landing page and Master Container mashups are present.
  • PTC.FSU.COREUI.MenuConfiguration.MasterContainer_EP loads successfully.
  • The All Applications icon is visible, but clicking it does not display any applications.
  • I am testing with the Administrator user.
  • Administrator is already a member of PTC.CWC.Default_UG.
  • Browser Network requests checked during page load are returning HTTP 200.
  • The landing page itself remains blank.
When I checked the Session section in Mashup Builder, UserMessage was not available.
Could you please advise what could cause the ThingWorx Applications landing page/application tiles to remain blank after a successful CWC 10.2 installation?
Specifically, I would like to confirm:
  1. Which user groups/permissions are required to access the CWC landing-page tiles?
  2. Is any additional COREUI/CWC menu configuration required after installation?
  3. Should UserMessage be available as a session variable by default, and could its absence be related to the blank landing page?
  4. Is there any post-installation configuration or validation required before the CWC application tiles become available?
Thanks in advance for your help.
    Support
    Oct 29, 2026 2:42 AM UTC
    Hi ​@Rahul Teja,
    I don’t think any post-installation configuration is required to show the CWC tiles.
    I have run into this issue once and resolved by clearing browser cache, can you give it a try?
    For groups/permissions, please check ThingWorx Apps 10.2 Help Center - Permissions and ThingWorx Apps 10.2 Help Center - Permissions > CWC
    Best regards, Tony
    mstarnaud
    Nov 3, 2026 1:01 PM UTC
    Hi Rahul
    - Administrator (user, and all users in that Group) doesn’t require any additional configuration, they should see all menu items. Non-administrator users should get the issue that you’re describing until they’re added to a Group.
    - TonyZhang has given a great suggestion of clearing the cache. To do this in Chrome : three dots button at the top-right → Settings → Privacy And Security → Delete Browsing Data → select All Time and Cached Images And Files → Delete From This Device.
    - On top of clearing the cache, we can clear the cookies, note that this should log you out of Thingworx. To do this in Chrome : three dots button at the top-right → Settings → Privacy And Security → Site Settings → View Permissions And Data Stored Across Sites → search for your Thingworx website → click on the trash can icon → Delete.
    - If the issue is not solved, we should look if the menu was correctly populated by the installation scripts. To do this, we need to check if in SQL, all 3 menu tables have records. We can execute the following query :
    SELECT 'menu', COUNT(1) FROM menu
    SELECT 'menucontext', COUNT(1) FROM menucontext
    SELECT 'menucontextlink', COUNT(1) FROM menucontextlink
    If you don’t have an SQL tool to make this query : go in Composer → open Thing PTC.FSU.CORE.LaunchPoint.LaunchPoint_TG → Configuration tab → go to DatabaseConfigurationSettings at the bottom (not the KPI one at the top) → open that SQL Thing → put it in Edit mode → go in the Services → Add (SQL Query) → give it a name → put the query in the code section of the service → Save → Execute.
    The results should be 3 numbers above 0. They should look something like 40, 7 and 90, but they could be lower/different for you. If any of them are 0, it means the menu data is missing and there was an issue in the installation. If that’s the case, you should create a support ticket so we can debug what exactly went wrong in the installation and add the missing parts.
    - If the issue is not solved, we suggest opening a support ticket and attaching a .HAR file. The HAR file will contain the list of Mashups and services called and their results, so we can compare with a working example and then debug the failure point. To get a HAR file in Chrome : click on F12 (this opens a panel) → go to the Network tab of that panel → go to the CWC main menu Mashup (open the menu’s screen) → at this point the Network panel should get some data, wait a few seconds to make sure all items are complete (no Status = Pending) → click on Export HAR.
    - When collecting the HAR file, if some services took multiple minutes to process (Status = Pending), it’s likely a connection issue with SQL. If that was the case, please do the following : go in Composer → open Thing PTC.FSU.CORE.LaunchPoint.LaunchPoint_TG → Configuration tab → go to DatabaseConfigurationSettings at the bottom (not the KPI one at the top) → open that SQL Thing → go in the Properties And Alerts tab → check the isConnected property’s value.
    If the box is not checked, then it’s not connected. If that’s the case, then go in the Configuration tab and review the connection string (JDBC Connection String setting). You can also try validating the username and password. If it stays disconnected, you can try executing the RestartThing service. If it’s still not connected, we suggest opening a support ticket.
    Let us know if any of these solutions solved your issue.
    pshashipreetham
    Nov 4, 2026 3:25 PM UTC
    Hey ​@mstarnaud .
    ​@Rahul Teja checked that the DB is connected:
    ​@Rahul Teja  went through an on-prem installer, which seems very new to me. When I re-downloaded and checked ‘Configuration’ folder is empty. Do we get empty folders when we download from the PTC Support Page ?
    Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
    mstarnaud
    Nov 4, 2026 5:10 PM UTC
    • So the SQL Thing is connected, great! That’s one suspect mostly eliminated.
    • If you also have the issue, then it’s very unlikely to be a cache/cookies issue.
    • Can you please run the SQL query I mentioned and say if the results are 0 or higher? It would show if the records are missing in the database and the installation script failed to create them, which is a big suspect.
    • If none of the above solve the issue, I strongly encourage you to open a support ticket and attach a HAR file as explained in my previous message.
    • I’m not very familiar with the new installer, but yes when I check mine that folder is empty, and my installation did work correctly. I strongly suspect that files get temporarily stored in the folder during the installation. At this point I’m not worried about this.
