Tia portal V17 exporter
When will the tia portal exporter utility support the version 17
I have huge data blocks. It takes 5 days to import....
Thats ridiculous.
Support
Hi @MB_10392957
Can you confirm which product you're using?
Thanks.
--Sharon
I need to export tags from Siemens Tia Portal V17 for kepserver ex 6.12 .
I've seen that Tia Exporter supports V16, i tried to install tia exporter but it cant be installed for Tia portal V17. do you know when it will be possible for Tia Portal V17?
Hi MB_10392957,
Sorry for the delay on this question.
Kepware does not have plans to support TIA Portal v17.
In KEPServerEX v6.11 we added the Siemens S7 Plus Ethernet driver to provide Symbolic access to S7-1200 and S7-1500 PLCs through the native S7 Comm Plus protocol. This driver supports automatic tag generation (ATG) so there is no longer a need to manually transfer tags from TIA Portal Projects.
The Siemens S7 Plus driver is included in the Manufacturing Suite and the Siemens Plus Suite.
Best Regards,
KC
Senior Kepware TSE
Nothing?
