Trend does not show the correct property value
Hi All,
I created a trend showing the OperatingMode property, butthe graph is not showing the correct values when I change the time range selection.
OperatingMode property values are the following (QueryPropertyNamedHistory service output):
The graph is correct when I select the time range
From 2019-07-31 07:00:00 -> To 2019-07-31 10:39:00
While the graph is not correct when I select the time range
From 2019-07-30 07:00:00 -> To 2019-07-31 10:39:00
The property value is not equal to 1 in the selected time range
Any idea? Many Thanks Martina
Hi All, I found that there is a JRA ticket saying:
  • MFG Trend functions which use Dygraph Widget, display average Y-axis value when X-axis time frame is over 1 hour to gain a better performance
  • An original-value-display improvement will be discussed in the furture after release of MFG 8.4.0
I have the 8.4.2 release installed, and the average is still displayed.
Thanks Martina
