Using an existing Middleware to feed Thingworx with information
I would like to implement a worker guidance using PTC Thingworx and PTC Vuforia.
Since we are not using any PTC software like Kepware as a middleware solution, I'm wondering if it is possible to using our existing middleware (soffico Orchestra & soffico Juno).
Can anybody tell me if it's possible? What kind of problems/challenges I need to consider?
Thank you in advance
Philipp
slangleyAnswer
Support
Hi @PD_9717258.
We don't have any information regarding your middleware solutions, but ThingWorx is open for accepting connections from third party products.  We accept REST calls and SDK's as well as an integration tool called Flow.
We suggest that unless someone has specifics on your use case that you try it and let us know if you run into specific issues.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @PD_9717258.
--Sharon
Support
Hi @PD_9717258.
If the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.  If you have further questions, please let us know.
--Sharon
