What is ThingWorx connection server ?
Hi ,
I'm new for ThingWorx platform , try to self study from the online document .
I have question about the purpose of using the ThingWorx connection server.
"ThingWorx Connection Server provides a server application that allows the connection of remote devices that use the ThingWorx AlwaysOn™ protocol to the instance of ThingWorx platform. This Connection Server handles all message routing to and from devices, providing scalable connectivity to ThingWorx platform."
For the Manufacturing App , it is look like ThingWorx connection server is doing the same task which KEPserver acting.
in the production environment I can choose between ThingWorx connection server or KEPserver to get the data from the remote device .
Is my understanding correct ?
Thank you
smainenteAnswer
The ThingWorx connection server is a concentrator for AlwaysOn agents, its purpose is horizontal scaling.
For example, it is not recommended to directly connect 30 000 AlwaysOn devices onto the ThingWorx platform; you shall interpose a couple of Connection Servers (for example 3 =10 000 devices per connector).
KEPserver can aggregates data from disparate devices and applications. It supports hundreds of different protocols.
smainente16-PearlAnswer
suriya1-VisitorAuthor
Thank you for the answer .
Another question , can I use KEPserver send the aggregate data from OT device then send that data pass to ThingWorx connection server ?
So the direction of connectivity is ,
OT Device -----> KEPserver -----> ThingWorx connection server ------> ThingWorx MFG app
Regards
What is an OT device and what communication protocol does it use ?
Regards
PS : Note that you probably don't need  a ThingWorx connection server with KEPServer .
