You are not entitled to the Composer feature. Please contact your PTC account team
I tried to install the 30-days Manufacturing Apps Developer kit Edition but encountered this error "You are not entitled to the Composer feature. Please contact your PTC account team" when running the composer. Is not the developer version should allow access to Composer?
hchananaAnswer
Hi Cheah,
To dig out more into the issue could you please share the below details:
- Exact url/link from where you downloaded the developer edition.
- Exact name of the zip file you installed on your system.
- Please confirm that no previous version of manufacturing apps was installed on your system.
- Are you able to access the Welcome Page of Manufacturing Apps on your system
Himanshu
Greetings Cheah,
In Developer Edition license ThingWorx server automatically shuts down after 30 days of usage and and it is non-renewable.
To assist you further on this could you please let us know when have you installed the Developer Edition and which version of Thingworx and Manufacturing app you had installed?
Best regards,
Himanshu
pcheah10-MarbleAuthor
Hi Himanshu,
I downloaded it from https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard and installed it today. I believe it is version 8.1.
hchanana16-PearlAnswer
Hi Cheah,
Himanshu
Chea,
You probably downloaded the Freemium version. It doesn't have composer access. In Learn section of that link, you will see Developer Kit, download and install it. That should give you full access.
If that is the case, it should be a bug. It should be fixed. Let me re-install and get back to you.
Greetings Peng Huat Cheah​
Following up with you on the original question posted here, can you please indicate if the recommendations given resolved this for you?
If there is a post that adequately answered your question, you can mark the reply as the "Correct Answer."
Or, if you are still unresolved on your original question, let us know and we can continue troubleshooting this with you. This feedback is a key step toward ensuring Community users with a similar issue are able to locate the information they need.
Best regards,
Steven M
I installed on a fresh install on a new windows 12 R2 instance. Everything just works for me.
Varathan
HI All,
Thanks for your help. I managed to make it works by reinstalling the Developer Version in a new server.
