Aug 8, 2024 11:25 AM UTC
How to restore a file
Hi, Is there any option to restore drawing in my workspace, I checked out the drawing from the server and this overwrote the latest in my local folder (there isn't any warning for that!!!)?
    Aug 8, 2024 1:42 PM UTC
    Probably not.
    You had file abc.drw in your workspace, revision B.4, which you then modified and saved.
    A checkout of abc.drw B.4 should not overwrite what is in your workspace.
    Going to the server and doing a checkout of abc.drw B.4 should also not overwrite what is in your workpace.
    Doing a download from the server of abc.drw B.4 to your workspace will overwrite the contents of abc.drw in your workspace.
    Nov 12, 2024 8:14 AM UTC
    Is this a Model Manager related question ? If yes, and some conditions, there could be some positive answer.
