Oct 28, 2022 1:59 PM UTC
Can i change the origin of my assembly?
Im modeling some chunks to export in .stp to mastercam. Can i set the origin  in creo elements/direct, so when i export my chunk to mastercam i allready have my "zero point" where i want?
Kotom-EngAnswer
Nov 2, 2022 10:11 AM UTC
Just type 0,0,0 in the input line and then [Enter] or click on the green arrow:
Oct 29, 2022 6:16 AM UTC
Create a new assembly which will be exported in stp. Copy all the sub-assemblies and sub-parts of the old assembly to the new one, method "2 Points", from the point you want to be the origin to the point 0,0,0.
Nov 2, 2022 8:44 AM UTC
Thanks for your reply, i undestand your solution perfectly, but using the "2 points" method, after select the point i want to move, where can i select the origin point (0,0,0)?
Kotom-Eng16-PearlAnswer
