3-Newcomer
May 14, 2026 9:57 AM UTC
Direct V19 on new laptop shows strange flyover selection clipping
Hi there,
I have used Creo Direct V19 on my old laptop for 4 years without issue (even worked when OS upgraded to Windows 11).
On transferring to a new PH ZBook Intel(R) Core(TM) Ultra 7 265H (2.20 GHz) Win 11 Creo now has strange clipping on flyover selection where the surface highlights in orange (as normal) but now the whole surface jumps in front of other parts, while before only the visible area would be highlighted.
After selecting a surface, the whole part also jumps to render in full in front of other parts.
When moving a part dynamically, the part (or assembly) will begin clipping and disappear as its is moved.
Switching off hardware acceleration (CPU only) resolves these issues but the frame rate is unusable.
The new laptop has the latest drivers installed for the Intel Arc Pro 140T (16GB) and NVIDIA RTX PRO 2000 Blackwell Generation Laptop GPU.
Just wondering if anyone else has seen this and found a solution to it?
Thank you Cal
