Mar 19, 2024 8:02 PM UTC
Does Creo Direct Modeling Express 8.0 run on Windows 11?
Just wondering if anyone has either gone through the Windows 10 to 11 upgrade while running Express 8.0 to see if it works, or has installed on a Windows 11 PC.
    Aug 12, 2024 6:16 AM UTC
    Creo Direct Modeling Express 8.0 is not officially supported on Windows 11. It was released before Windows 11, and support typically aligns with operating systems that were current at the time of the software’s release.
    For the best performance and compatibility, you might want to use it on an operating system that is officially supported, like Windows 10. If you do try running it on Windows 11, you might encounter compatibility issues or need to adjust settings to make it work.
    RJH19844-ParticipantAuthor
    Aug 12, 2024 8:05 PM UTC
    Thank you. I have been running it now for a while and it seems to work fine.
    der_Wolfgang
    Aug 14, 2025 4:37 PM UTC
    Creo Elements/Direct Modeling Express 9.0 was published round about in May 2025 (based on my personal investigations).
    Part of the ===>> System requirements  (as mentioned in the official PTC page) is.
    • Operating System:
      • Windows 10 64-bit Editions: Windows 10, Pro and Enterprise
      • Windows 11 64-bit Editions: Windows 11, Pro and Enterprise
    So, you might wanna update your installation..
    One issue that has been resolved for now is the problem of the server not responding when trying to enable Creo Elements/Direct Modeling Express via the activation key. This problem had been ongoing for several years, with many requests and much confusion here (and in other forums as well).
    ● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
