6-Contributor
Apr 13, 2020 6:43 PM UTC
Embossing Text on cylinder in Creo Elements Express
Hello all,
     I'm trying to emboss text on a cylinder in Creo Elements Express.  I do the following:
1) Create cylinder
2) Create workplane parallel to cylinder face
3) "Modeling->Modify 2D->Text to Profile" the text onto the workplane
4) "3D Geometry->3D Curve->Wrap on Surf" the text onto the cylinder
     ...At this point I can use "Modeling->Modify 3D->Pull" to emboss the text, but it embosses linearly, as opposed to embossing out relative to the surface of the cylinder.  I suspect I should be using "Modeling->Modify 3D->Offset", but I can't figure out which set of options (if any) can accomplish this.
      Any ideas?
      -BW
Apr 14, 2020 12:40 PM UTC
I am not able to test this myself, but what if you created a work plane perpendicular to the axis of the cylinder.  Draw a circle on the cylinder and align the faces to the circle?
BenW6-ContributorAuthor
6-Contributor
Apr 14, 2020 1:35 PM UTC
I'm sorry, I don't understand what you're suggesting. If I draw a circle on the workplane, then wrap it onto the cylinder, how do I use that to solve my problem?
Apr 14, 2020 1:47 PM UTC
This is a feature introduced in V19.  You can align faces to geometry.  Look at this tutorial on the PTC website.
https://learningconnector.ptc.com/content/tut-3481/reviewing-enhanced-align-functionality?isNew=false
I hope this helps.
Jan 23, 2023 5:26 AM UTC
Have found a video about this.
Maybe this is more helpful
PTC Creo Elements Direct Modeling Express | Kante auf Fläche (gebogen) Teil 2 - YouTube
Have a nice day
