6-Contributor
Apr 24, 2026 1:48 AM UTC
How to batch rename all parts in an assembly with sequential serial numbers? (Creo Elements/Direct Modeling)
Software: Creo Elements/Direct Modeling 19.0
Goal: I am looking for a way to automatically rename all components (parts and assemblies) within a specific top-level assembly using a sequential naming convention (e.g., PART-001, PART-002, PART-003...).
Details: Doing this manually in the Structure Browser is extremely time-consuming for large assemblies. I would like to find a solution (either a built-in command or a LISP script) that allows me to:
  1. Select a Parent Assembly.
  2. Define a Prefix (e.g., "MYSYSTEM-").
  3. Automatically apply a three-digit increment (001, 002...) to all children.
Questions:
  • Is there a hidden command in the standard UI that supports "Prefix + Increment" renaming?
  • If not, does anyone have a LISP macro or utility that can automate this task?
  • Are there any "Best Practices" to avoid naming conflicts when doing this in a large session?
Any help, sample code, or advice would be greatly appreciated. Thank you!
6-Contributor
Apr 27, 2026 1:18 AM UTC
Solved: Developed a custom LISP tool to batch rename parts.
I have solved this by writing a custom LISP utility. The script allows the user to select an assembly, define a prefix and a starting number, then automatically assigns sequential serial numbers to all direct parts within that assembly.
Key Logic:
  • Uses sd-defdialog for a user-friendly interface.
  • Utilizes sd-inq-obj-children to identify child objects.
  • Filters for parts using sd-inq-part-p to ensure only parts are renamed, leaving the assembly name intact.
ZL_145694426-ContributorAuthorAnswer
6-Contributor
Key Logic:
der_Wolfgang
Apr 29, 2026 5:25 PM UTC
you might like the dialog for ‘Strukturliste aufräumen’  / “Clean up the structure list”     which can be found here :   https://osd.cad.de/lisp_3d_38.htm
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
6-Contributor
Apr 30, 2026 1:58 AM UTC
THX
