Aug 18, 2026 9:22 AM UTC
Try running the application with administrator rights.
der_Wolfgang
Aug 18, 2026 11:04 AM UTC
  • file access:   Try top open your file with any other application, e.g. a hex.viewer or even notepad
    • can you open it?   What is displayed : screen snot required
  • file read access:
    • copy n’ paste the following snippets into your Modeling command line:
      using YOUR file, and use FORWARD slashes in the full file path name
      • (display (oli::sd-inq-file-status "c:/work/yourfile.xyz" :existence))    => should be T
      • (display (oli::sd-inq-file-status "c:/work/yourfile.xyz" :read-access))    => should be T
    • what are the results?
  • file type:  what kind of files do you try to open?
    • package files ‘*.pkg’ ?
    • bundle files ‘*.bdl’ ?
    • SD files ‘*.sd*’ ?
    • MI files ‘*.mi’ ?
    • BTW : ‘CAD’ file is not the right answer!
  • try to open the files via the User Interface => “File”  => “Open”
    • what kind of “File type do you choose” ?
    • send a screen shot of your situation JUST before you press “Load”
Last but not least:
  • provide the EXACT error message (as text or as screen shot)  -- the information you gave is not sufficient
  • did drag n’ drop of the (same) files work 1 week ago / 1 month ago?
  • which system / Modeling version has written the file?
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
