Jul 2, 2025 7:42 AM UTC
Select with cursor unavaliable PTC Creo Elements/Direct Modeling 20.5.2.0
I'm having a problem with PTC Creo Elements/Direct Modeling 20.5.2.0 : Sometimes I loose the little "cross" next to the cursor resulting in me unable to select anything (see attached files). I tried to close the viewport but nothing changed. The only way to get the cross back is to restart Creo.
I can't find a way to reproduce consistantly the problem. I get this issue 1-2 per week.
I hope someone can help me.
Cheers !
Jul 2, 2025 10:12 AM UTC
I had such behaviour or similar after changing 3D viewport parallel / perspective.
But a restart was also necessary.
Catalina
Community Manager
Jul 8, 2025 1:08 PM UTC
Hi @MR_13244953
Thank you for your question.
Your post appears well documented and has received a response, but no resolution so far. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina | PTC Community Manager
