Feb 25, 2025 10:10 AM UTC
Silent Installation Fails for Creo Elements Direct 20.7.1.0
Hi all
I have a problem with a silent installer for Creo Elements Direct.
Before i have created an installer for Creo Parametric(which work well) and i re-use the base of it.
According to CS136223 (https://www.ptc.com/en/support/article/CS136223 ) and CS414799 (https://www.ptc.com/en/support/article/CS414799 ) I do the following:
Creo Elements Dispatcher:
setup.exe /s /v"/qb- INSTALLDIR=\"<Path to Base Directory>\Direct Dispatcher 20.7\""
Finite Elements:
setup_fe.exe /s /v"/qb- INSTALLDIR=\"<Path to Base Directory>\Direct Finite Element Analysis 20.7\""
Even the License Server works kind off(looks like it installed something but i miss the shortcuts to the web browser)
setup_sdserver.exe /s /v"/qb- INSTALLDIR=\"%CREO_LOADPOINT%Direct License Server %RELEASE_SHORT%\""
But Creo Elements, I don't get it to work. It just don't install. Not in my specified location, not in programfiles
Below the example from: https://www.ptc.com/en/support/article/CS136223
SETUP.exe /s /v"/qb INSTALLDIR=\"<Path to Base Directory>\Direct Modeling 20.7\" MELS=\"<LICENSEHOST>\" ADDDEFAULT=\"BINNT,PERS,RENDER,L10N_DE,HELP_EN,IKIT\" /lvx* \"<Path to Base Directory>\osdm.log\" "
And this one doesn't work eighter.
Is something changed? or am i missing something?
Catalina
Community Manager
Mar 5, 2025 9:44 AM UTC
Hi @jw_CS
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
jw_CS14-AlexandriteAuthor
Mar 5, 2025 3:56 PM UTC
Thank You
der_Wolfgang
Apr 16, 2025 5:48 PM UTC
I used a tiny batch to perfom (almost) your command sequence ..
SETUP.exe /s /v"/qb INSTALLDIR=\"c:\temp\Direct Modeling 20.7\" MELS=\"localhost\" ADDDEFAULT=\"BINNT,PERS,RENDER,L10N_DE,HELP_EN,IKIT\" /lvx* \"c:\temp\osdm.log\" "
followed by
wmic.exe product get name,version,InstallDate | findstr /I "ptc modeling"
this worked fine for me.
Be aware that the SetupPrerequisites
  • PTC Creo Platform Agent
  • PTC Creo 11 Platform Services
  • PTC Diagnostic Tools
got installed into their default install directories
What I definitely changed is the location of the installation log file. When I saw your command I thought immediately that using the base-install dir for the log file as well might not be a good idea. Therefore I changed it (to my temp dir). That might be the difference.
At the end I got:
20250416 PTC Creo Platform Agent 1.7.121
20250416 Creo Elements/Direct Modeling 20.7.1.1 ( x64 ) 20.7.10001
20250416 PTC Creo 11 Platform Services 1.0.134
20250416 PTC Diagnostic Tools 11.0.3.0
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
