11-Garnet
Jun 18, 2024 12:15 PM UTC
sketch child of the frame
How can I load a sketch via command line that is placed as a child of the frame?
In my case I would like the "logo" sketch to be placed as a child of the "cart_A3" frame
the command line command to load the sketch is:
sd-am-load-sketch
I' have Creo Elements/Direct Modeling 20.5.1.0
    Jun 18, 2024 8:38 PM UTC
    Andrea
    This response is edited, as I found a much better way of doing it than my original response.
    Code:
    (sd-am-load-sketch :file_name file_name :position position
     :owner_type :current-frame
     :owner owner <- you do not need this if you set the owner_type to :current-frame.
     :adjust adjustment)
    Since
    Code:
    :current-frame
    is set as the
    Code:
    :owner_type
    , you will not need to fill out the
    Code:
    :owner field
    . That is only used if you want the owner to be a specific view or specific sketch.
    Adjustment
    Code:
    :upper_left
    :upper_middle
    :upper_right
    :middle_left
    :middle_middle
    :middle_right
    :lower_left
    :lower_middle
    :lower_right
    Regards
    Tom
    __________________
    Tom Kirkman
    Creo Elements/Direct 20.1
    Dell Precision 3581
    https://www.o-i.com
    olivierlp
    Community Manager
    Jun 26, 2024 1:31 PM UTC
    Hi @AR_01  ,
    I wanted to see if you got the help you needed. If so, please mark the reply as the Accepted Solution. It will help other members who may have the same question.
    Olivier
