Aug 18, 2022 7:11 PM UTC
Structural Shape Database
Our company uses a lot of structural shapes in our designs (wide flange beams, channels, angles, etc..). We have start parts for things like plates, round tubes, etc.. and would like to have start parts of the other structural shapes as well. With these start parts, we would like to be able to have all the sizes for each shape loaded into it, so mid design it is easy to change sizes if needed.. Currently, we have start parts set up for these and pull the dimensions from an excel sheet. The problem with this is anytime you start a part, or want to change the size, you have to re-open excel and reload it which is time consuming as there is some bugs in doing this.
We tried to do this using family tables and it works, however, we have issues with naming when we try to change sizes. The items in our BOM are populated based off of our item names, and the family tables requires the name to be changed everytime you change sizes. So because our part names cannot change mid-design, it doesnt seem like this is going to being able to work.
Does anyone know of the best way to have structural shape parts/libraries?
Thanks.
    Aug 18, 2022 7:58 PM UTC
    I modified a lisp program a long time ago that was strictly metric to include imperial sizes.  I generates a profile on a work plane and extrudes or bends it to your specification.  You can name the part as you create it.
    I am attaching a screen shot of the menu.  Let me know if you are interested.
    Tom
    Aug 18, 2022 8:27 PM UTC
    The Advanced Framework Extension has structural steel shapes.
    Aug 18, 2022 8:30 PM UTC
    If this is for Creo Parametric, yes the Advanced Framework Extension works.  But if it is Creo Elements/Direct Modeling, it is not available.
    Aug 19, 2022 2:35 PM UTC
    A couple of ideas that may or may not help ...
    - Use a logical table for the shapes data.  In house we converted the AISC shapes data base (comma separated file) into a logical table as a LISP file.  We autoload this at start-up.
    - We parametrically constrained the different shape types (Channel, WT, L, etc.)
    - We wrote a few LISP macro's and dialog boxes that allow us to take an existing shape type and update its size.  This allow us convert an L 8x8x1/2 to an L 8x8x1 using a selection list.
    It may also be worth looking into Kleitsch.  They have a parts assistant package for Creo Elements Direct Modeler that may be useful for what you are doing.
    Apps for PTC Creo Elements/Direct Modeling | Klietsch GmbH
    Aug 19, 2022 5:23 PM UTC
    Is there a way to do this in creo parametric?
    Aug 19, 2022 6:09 PM UTC
    Not sure as we do not use that package.
    Sent from Mail for Windows
