What rendering software work best with element direct.
I am looking to do some rendering but element direct PE dosent have any software intergrated.
So what software do you recommand to do realistic rendering?
Keyshot is a great program. A lot of CAD vendors use Keyshot as an engine for there renderings.
This will also be implemented in Creo 4.0 I believe.
Keyshot can load .stl files.  It will work well with Express.  We use Keyshot for advanced rendering.  I have a full version of modeling and the built in rendering is very good for most presentations.
Regards
Tom
What do you mean by "PE"?   Express Version? or something different?
Im am not sure if Keyshot works with the Express Edition.
Opyone1-VisitorAuthor
I am using Modelling Express, is it ok with it?
How the import works? iis the definition of the surfaces ok?
Hi, I suggest you install the trial version of Keyshot (for 14 days I think).
It's really easy to use.
Check what files you can export using Modeling Express. If you can save STEP or STL, you're fine.
