Callout Partnumber Annotation in Creo Illustrate 2.0
Is it possible in Creo Illustrate 2.0 to change the attribute in the Callout Partnumber Annotation from "PARTNUMBER" to some Parameter that is existing in my Creo prt files?
I found in the C:\Program Files\PTC\Creo 2.0\Illustrate\resources\pvplugins\galaxystartup\text\resource\CalloutTemplates.xml
Line 122          <useproperty category="PROE Parameters" name="PARTNUMBER"/>
but the change is not used, since a dll is precompiled and thus the changed option is not used.
Does anyone know a trick or how to use other Parameters in Annotations?
