Creo Schematics 7 : pdf export inaccurate
I am using Creo Schematics 7.0 7.0.0.0
pdf export does not display properly dashed lines, labels, reports (text is within case on Creo but outside case in pdf export).
Only workaround so far is to use third-party pdf printer (time consuming, especially with different documents with multiple pages to print)
    You can submit a support case here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
    Hi Julien,
    Can you share a sample design (removing any proprietary information) and incorrect PDF output so that we can take a look at it?
    Nirmalya
    jmarchal1-VisitorAuthor
    Hi Nirmalya,
    You will find enclosed 2 samples, Creo7 printscreen vs pdf export
    Regards
    I second this issue, has it ever been resolved?
