Derived Parameters
Are there any additional default system functions to be used for creating derived parameters other than the following:
dg_inherit_from_ancestor
dg_inherit_from_connected
dg_derive_from_enclosure
dg_derive_indirect
dg_derive_indirect2
dg_derive_as_label
Can any of these be used to propagate a property value from one port to another?
Thank you.
Catalina
Community Manager
Hi @JS_MM
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
JS_MM10-MarbleAuthor
After further investigation, my issue is not as specific as my initial request.
Should I continue to explain what it is that I'm looking for in this thread, or start a new thread more specific and detailed to my issue?
I'm struggling through this right now.
If you have a fiber connecting two ports, you can use dg_inherit_from_connected(forward, wiring, name_of_parameter, 1) to take a user defined parameter from the connected port, and dg_inherit_from_connected(forward, wiring, name_of_parameter, 2) to take the parameter from the connected parent of the port.
I can't figure out how to get the port's name however.
