Error: A design does not exist at specified location
I am using Creo Schematics 4.0 M010
Software gives an error when trying to open the attached drawing: A design does not exist at specified location
Here are the errors that I faced
    Thanks. I opened also C15792003.
    Usually this is because of corrupt data. To have a look at it and probably correct them, a case needs to be opened at PTC. Link: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
    I opened C15798014. You will be contacted by PTC. You may accept this as solution for this community thread.
    CP_88403601-VisitorAuthorAnswer
