Error message when opening a file in .edz format wiht Creo View Express 12.0
Hello.
I have a project in which I use AutoCAD. I have several files in .edz format that I need to open to convert them to a format compatible with AutoCAD.
I open one of these files in Creo View Express 12.0:
And the following message appears:
Does anyone know the reason for this error and how to resolve it?
Thank you in advance for your answers.
VladimirNAnswer
Article - "Creo View displays "An error occured locating a product structure in the ZIP archive" when opening a previously saved .PVZ": https://www.ptc.com/en/support/article/CS81367
Same issue - "Can somebody see if they can open this pvz file?": https://community.ptc.com/t5/3D-Part-Assembly-Design/Can-somebody-see-if-they-can-open-this-pvz-file/td-p/257308
Catalina
Community Manager
Hi @DD_13881493 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
VladimirN24-Ruby IVAnswer
